SpotlightInserting stage steps
Mode
Tool
Tool set
Stage Steps
Event
The Stage Steps tool inserts portable steps typically used with temporary stage structures into a drawing. The type, shape, size, appearance, and presence of railings can be customized.
To insert stage steps:
Click the tool and the insertion modes.
Click to place the object in the drawing, and click again to set the rotation.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette. Some information from parameters can also be placed on the drawing using the Text Options
Parameter
Description
Structure
Select the style of stage steps; self-adjusting steps have a fixed stringer length and number of steps, and the step rise automatically adjusts to fit the stage height. For the other types of steps, the step parameters are determined according to the selected Create Based On option.
Create Based On
When steps are not self-adjusting, specifies the method used to determine the step parameters, either by setting stage height and number of steps, or by setting the number of steps and the step rise. Depending on the selection, certain step parameters become available, while the other parameters are calculated for display.
Stage Height and Number of Steps: Calculates the height of the steps and the rise automatically based on the height of the stage and the specified number of steps
Number of Steps and Step Rise: Calculates the height of the steps and the stage height based on the specified number of steps and the step rise
Stage Height
Sets or displays the height of the stage
Step Unit Width
Specifies the width of each step
Stringer Length
(self-adjusting steps)
Specifies the length of the stringers for self-adjusting steps
Stringer Width
(self-adjusting and open free-standing steps)
Sets the width of the stringers for steps with stringers
Stringer Type
(open free-standing steps)
Select whether the stringers are located inside and under the treads, or outside the treads (the stringer width setting affects the available step area)
Add’l Stringers
Adds one or more additional support stringers to the steps, spaced evenly based on step width
Side Stringer Indent
(open free-standing steps, inside stringers only)
Moves the outer stringers in (underneath the steps) on each side of the stair by the specified distance
Draw Arrow
Select whether to display an arrow in Top/Plan view; the arrow can point up or down. In the Text Options, select the arrow text label to display the word "Up" or "Down" in the drawing.
Arrow Size
When drawing an arrow, sets the arrow head size in drawing units
Step Details
Number of Steps
Specifies the number of steps
Add Top Step at Stage Height
Adds an additional step at the top of the flight, set to the same height as the stage
Top Step Height
Displays the height of the top step
Single Step Rise
Sets the distance from one step to the next
Step Thickness
Specifies the thickness of each step
Single Step Depth
Specifies the depth of each step
Nosing Depth
Sets the nosing distance (the depth the step protrudes from the stringer)
Top Color/Texture
Displays the texture or color selected in the 3D Options
Trim Color/Texture
Pitch (Calculated)
Angle
Displays the pitch of the stair as an angle
Ratio (rise:run)
Displays the pitch of the stair as a rise-over-run ratio
Percent (Grade)
Displays the pitch of the stair as a grade percentage
Leg/Structure Details
Profile
(frame free-standing steps)
For the Legs-Basic structure type, select a round, square, or octagonal shape
Color/Texture
Railing Details
Show Left/Show Right
Select whether to show a railing on the left only, right only, or both sides. Railing parameters apply to both sides.
Height
Specifies the height of the top railing
Add'l Whole Railings
(frame free-standing, simple, solid free-standing, or open free-standing steps)
Adds one or more additional railing sets to the steps, spaced evenly based on step width
Add'l Horiz Bars
Adds additional horizontal bars to the railing; this parameter is only available when the left and/or right railing are selected for display
Add'l Uprights
Adds additional upright bars to the railing; this parameter is only available when the left and/or right railing are selected for display
Profile
Select a round, square, or octagonal railing shape
Color/Texture
3D Options
Specifies the appearance of applicable step elements in 3D views. The 3D Options dialog box opens.
For each available portion of the steps, either select the color from the Color list, or select Custom Texture and then click the current custom texture to open the Resource Selector; double-click a resource to select it. The Object Info palette displays the color or texture selections in the relevant section.
The appearance of Simple stage steps is set from the Attributes palette.
Location, Position, Unit, Purpose, Set Cart ID, Brand, Model, Vendor, Cost, Note
Adds information which can be placed on the drawing or used for reporting
Text Options
Opens the Text Options dialog box, to enable the display and format the text of labels
Default Text Positions
Restores text labels to their default positions
Classes
Opens the Classes dialog box, to specify class naming for the various portions of the stage steps. This allows portions of the stage steps to be set to visible, grayed, or invisible.
Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Select <Stage Steps Class> to place the stage step element in the same class as the stage steps.
Class Prefix: Specifies an optional default root class naming standard for all stage step parts; click Assign Default Classes With Prefix to begin all stage step class names with the prefix, so that they are sorted together.
Assign Default Classes With Prefix: Sets the class names for all stage step elements to the standard, using the Class Prefix if there is one.
Stage step elements: For each portion of the stage steps, including the loci that represent the center of the stage step legs for certain Structure types, specifies the class name standard; the class names shown here are applied to the elements.
Update
Updates the object when changes have been made to the Object Info palette parameters
Equipment Subparts
Lists the subparts that make up the object. These subparts are counted and reported separately in equipment and inventory lists.
The parameters must be selected for display for this type of object in Spotlight preferences: Inventory pane.
Equipment Virtual Parts
Virtual parts are associated with an object and are reported in equipment and inventory lists, but do not display in the drawing. After adding virtual parts, they are listed in the Object Info palette.
Edit Virtual Parts
Opens the Virtual Parts dialog box to add virtual parts to the object; see Managing virtual parts and independent virtual parts
Assign Sources
Opens the Assign Sources dialog box to assign the object and its subparts and virtual parts to an inventory source; see Assigning equipment to an inventory
Formatting stage step labels
